Old 10-06-2008, 10:53 PM
rgarza9311 rgarza9311 is offline
Default Poly or OEM?
Looking for a master bushing set for my 68 GTO, but I don't know the performance difference between Poly bushings and OEM rubber bushings. The car is going to be a daily driver, not a racer. Looking for a stiff suspension in turns but I don't want to feel every pebble on the road. Any thoughts or ideas? Also looking for a good product if you know any. Thanks in advance.
Old 10-07-2008, 02:31 AM
deuce_454's Avatar
either high durometer rubber or del-alum... poly squeaks.... good shocks and tires will get you far, if you want more you should do it right.. box the frame, and add a full suspension global west, airride, hotchkis or whatever... but do everything,
for a daily id get the airride, its a full kit and it will blow your mind how big the difference is!
Jake: Hit it.
