Old 10-09-2008, 09:17 AM
Hotchkis Hotchkis is offline
senior member
Post 67-69 Camaro/Firebird "Chassis Max Sway Bar Brace"
Part # 1415
MSRP: $201.95
We've just released an upgrade to the current 67-69 sway bar kit...
Link to product: http://www.hotchkis.net/p-824-67-69-...bar-brace.aspx
Old 10-09-2008, 04:36 PM
class67's Avatar
class67 class67 is offline
Aahhh, there we go! need a joe smoe to do a garage install and report back to everyone as to how easy it is....lol j/k.
I'll have to order one soon.
Steve
67 Camaro RS
66 Chevelle (in progress)
Old 10-16-2008, 04:50 PM
sik68's Avatar
sik68 sik68 is offline
To Hotchkis (or others with knowledge of the chassis),
Do you consider the rear of the 1st generation F-bodies to be flimsy (for lack of a better term)? Relative to your subframe connectors (which I plan to purchase soon), how important do you consider this brace for chassis rigidity?
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 10-23-2008, 10:08 AM
senior member
The word flimsy definitely pertains to the Camaro chassis when you add high horsepower, super sticky tires and monster brakes. The Camaro is old, and that’s why we love them. The chassis was not designed to take the stress of state of the art performance parts. Back in the day, a full race set up was 400hp and relatively narrow bias ply racing tires. That was it! Now your typical well built street small block makes over 400hp before the power adders. Attach a few turbos, some clever ECU programming and over 1000 hp is a no brainer. Add some 265+ extreme performance tires, some massive aftermarket brakes, or even some really good brake pads/rotors, and your stock Camaro chassis doesn’t have a chance. Talk about twist and flex! Now you may never outfit your Camaro with these extreme go fast goodies, but increasing the grip level and adding a modest amount of power will over stress your stock chassis. Good subframe connectors add substantial strength by tying in the subframe to the leaf spring chassis pick up point. They also reinforce the pick up point which is a weak spot, especially due to the shock of hard launches. Finally, because many enthuiasts don’t want to cut their floor, you should look into subframe connectors that install without modifications to the floor structure. Bottom-line, well built subframe connectors are essential Camaro chassis reinforcements for drivers that enjoy spirited driving and honest chassis feedback. And of course, nobody likes chassis flex and body cracks.
Thanks for asking!
