Old 10-09-2008, 04:00 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default One Glowing Header Tube???
Hey guys,
Here is the situation; I just built a brand new engine (sbc 355) for the Nova. Went to break it in and after about 5 minutes of running it at around 2500rpm to break in the cam i notice that the header tube on cylinder #5 is glowing red hot. None of the other cylinders are glowing. What could cause this on only one cylinder? Also i noticed some white residue inside the tube when i removed the header. Any help is greatly appreciated.
Thanks,
Brian
Old 10-09-2008, 04:21 PM
Lean condition on that cylinder. What does the plug look like? Check for a vacuum leak at that intake runner.
Old 10-10-2008, 12:41 PM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
I would check the exhaust valve adjustment also and look for a tight exhaust valve.
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 10-10-2008, 03:42 PM
70TWO NOVA's Avatar
thanks, will do
