Old 08-29-2005, 08:01 AM
threestar40 threestar40 is offline
Default Crankcase Vacuum
Anyone want to talk about crankcase vacuum in a forced induction application?
I know about venting through the valve covers with with breathers, but in a turbo application, would it be prudent to use a vacuum pump and if so, how would it be plumbed exactly.
I've seen the set up many times in a race application, they just dump into the headers, but in a street application, that would obviously be unacceptable because of the unavoidable oil that would end up in the exhaust stream.
Thoughts?
Rick =)
Old 08-29-2005, 02:52 PM
slow4dr's Avatar
slow4dr slow4dr is offline
Thoughts?
Rick =)
"catch cans"
Greddy makes a nice one.
This will keep oil out of the intake tract while still allowing proper crankcase ventilation
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 08-29-2005, 02:55 PM
slow4dr's Avatar
You will need to run a line before the turbo inlet to the catch can. This is the only place that always sees vacuum. The other line from the catch can will go directly to the valve covers.
Old 08-29-2005, 05:33 PM
Kick Ass.
Thanks Jason =)
Rick
Old 08-30-2005, 02:50 PM
Y-TRY Y-TRY is offline
What are some choices for valve cover breathers? Anyone see particularly cool stuff out there?
Old 10-23-2005, 10:32 AM
hotwheels's Avatar
hotwheels hotwheels is offline
i am running a twinturbo mustang and just have breather's on my valve cover's and they aren't that expensive, just the cheap one's that are colored blue from autozone......
a friend of mine built his own catch can using one of those little oil/water seperator's you buy for a garage air compressor........work's really good....
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
