Old 10-17-2008, 02:40 PM
74ls1nova 74ls1nova is offline
Default LS1 parts,Inline 255 pump, EV carb hat
Set of coil packs, with brackets and harness's off 01 Z28 110
2 sets of stock lifters and trays 25.00 each
Stock pushrods 20.00
Z06 Red stripe valve springs and retainers 20k miles 75.00
LS2 chain and upper cam gear 20.00
Rollmaster Double roller chain, Less than 5k miles do NOT have oil pump shims 60.00
Pair of Barely used knock sensors 30.00
Good used Cam sensor 20.00
EVAP purge soelnoid 20.00
Good used starter 50.00
Walbro 255 lph Inline pump. Has less than 50 miles on it. Worked great no issues. 80.00
Summit -8 filter Not sure which micron it is, It was before the pump. 20.00
Aeromotive regualtor 13101 Less than a 1000 miles works great has 2 -8 and a -6 fitting in it 100.00
One set of 317 heads, Disassembled but complete. 150.00
One set of 241 Heads. Complete off a running 01 Z28
One set of 853 heads Complete with Manley springs and retainers good to .600 lift. Less than 5k on springs 175.00
LS1 front cover 15.00
LS1 rear cover 15.00
Mahle forged pistons Part #LS1314905F04 Less than 2K miles
3.905 bore 6.125 rod .927 pin. Set of 7 200.00
Extreme Velocity Carb hat 4150 style Oringed. Minor scratches 125.00
All prices OBO plus shipping.
Will post pics later.
Thanks David
Old 03-27-2009, 01:46 PM
jix jix is offline
Default hi
still have the ev hat
