Old 10-24-2008, 10:27 AM
g356gear's Avatar
g356gear g356gear is offline
Default Stock Body - conflicting tire sizes
Hey guys,
I have a stock body 69 BB coupe that I am looking at giving a more aggressive stance. I am looking at the DSE Speed kit 1 (2" drop+ 18" rims) in the front and a Leaf spring (3" drop+ 20" rims) rear on the car. I don't want to cut up the body or subframe at all, so that is my reasoning for going this direction. My problem is some different information I have gotten on what rim size will fit the stock body with the lowered suspension mods.
DSE and Fikse say you can go 8" front and 9.5" rears maximum width. I have talked to other wheel manufacturers who say that on their project cars they have only been able to run 7" front and 8.5" rears without rub issues on the fender edges.
Any feedback would be appreciated.
Old 10-24-2008, 01:55 PM
7TSS's Avatar
7TSS 7TSS is offline
My friends have 69 Camaros w/ 17 x 8 on 245/40's front and 17 x 9.5 on 275/40's rear.
Their drops were similar to what you're planning. As long as the overall tire height is about the same I don't see why you can't run the same widths using different wheel diameters. If you decide on taller tires, that would be a different ballgame.
You might want to check this site for other opinions http://www.camaros.net/
Goodwin
Old 10-24-2008, 02:08 PM
Anyone who tells you that you can only put a 7" wide front, and 8" to 8.5" rear wheel on a 69 camaro doesn't know what they are talking about.
We've been building wheels for 1st gen camaros for quite sometime. Not to mention owning, and building a few of our own. A 8" wide wheel on the front, and a 9-9.5" wheel on the rear is a perfect fit. I'm sure if you search around the forums, you will find that is the general consensus.
Old 10-24-2008, 02:17 PM
g356gear's Avatar
And that's why I wanted to get the straight info on the scenario. This info was from a manufacturer of 3 piece wheels who supply to pro-touring owners. You would think they would know what they are talking about.
Old 10-24-2008, 02:54 PM
camcojb camcojb is offline
possibly with their wheels you cannot get the correct offset to run 9.5's in the rear and 8's up front; doubtful, but that's the only thing I can think of that would make them make that statement.
Old 10-24-2008, 03:20 PM
g356gear's Avatar
He was basing his opinions off of cars they had in their shop with virgin quarters. He said aftermarket quarters may have a little more clearance. Not sure if that is the case or not, but mine are originals.
Old 10-24-2008, 03:41 PM
I've done several, and all that I have done have had their original GM quarters.
