Old 10-24-2008, 05:59 PM
malli383 malli383 is offline
Default A/C decision for a '66 chevelle
I'm hoping to install A/C in my chevelle project but I'm not sure which one to go with. I have a smooth firewall and the car didn't have factory air (no vents in dash). Any suggestions?
Old 10-24-2008, 07:52 PM
novanutcase's Avatar
Vintage Air or Hot Rod air should have everything you need to set it up properly.
John
Old 10-24-2008, 09:22 PM
Vintage Air does a Sure Fit for your car using the older cable style version. The old style Sure Fit will work with your original controls, but it is not up to par with the new Gen IV system. We do a custom kit of our own that uses a Gen IV Magnum and a combination of parts we assemble to fit your car, that IS NOT a Vitage Air "kit" but uses all selected Vintage Air components. You will have to use a custom controller we will supply with our kit, not your factory controls.
We do a lot of Vintage Air. We also have Hot Rod Air and Classic Air. But the Gen IV is the baddest on the block bar none. Call me if you would like to discuss details.
Frank Serafine
