Old 10-29-2008, 01:03 PM
Stale67SS's Avatar
Stale67SS Stale67SS is offline
Default Molding pin studs, 67 Camaro
I have replaced some body panels and are going to weld in new pin studs for the rear window molding.
Anyone got a picture of where these are placed originally?
Stale Feroy (Norway)
"If you're under control you're not going fast enough"
Old 11-03-2008, 11:24 AM
2Bad4Ya's Avatar
2Bad4Ya 2Bad4Ya is offline
I dunno about the welding, I simply bought the screw in replacements and measured from bottom of channel up to center of an existing stud or two, then drilled/screwed in the screw.
http://www.FQUICK.com/2Bad4Ya
