Old 11-05-2008, 02:27 PM
Ravenous70's Avatar
Ravenous70 Ravenous70 is offline
Default 1970 LS1'd Camaro
Well been lurking here for awhile so I'll introduce myself and my father and I's project. I call it "theBitchin Camaro"
Started out as a Ebay special 1970 Camaro with a ZZ4 Crate motor, after not being able to sell the car (was looking for a 64-72 El Camino to haul my bike in) we deceided to put my favorite motor, an LS1, in her. Found a 99 LS1 on LS1tech here locally in DFW and started from there. Contacted Futral Motorsports since most of the off the shelf cams are for fuel injected LS1's and I wanted to kinda mix the old with the new in this project. Gave Futral the specs on the Heads I was running (mildly worked LS6 heads) and other information they needed. Assembled the motor using a short block as a basis but upgrading the rod bolts for strength. List off all the parts used on my cardomain page. Had a local shop install the motor, which they did a beyond what was needed job and made it look factory installed (IMHO) We are now installing C5 Front brakes and 4th Gen F-body rear brakes. Later more suspension work is needed but its running and I can take it to work on rainy days (I ride a motorcycle nearly all of the time)
This is not my 1st run in with classis car projects, my 1st was a 1966 Chevelle with a 454 in high school, then a 1970 340 Dart Swinger, then a 1970 Plymouth GTX & 1966 Plymouth VIP Fury. The Gtx was a our most customization project, wasnt as much as most of the guys on here but alot for 2 guys in a garage So wish me luck and thanks for looking
1970 Camaro http://www.cardomain.com/ride/3069774
1970 Plymouth GTX http://www.cardomain.com/ride/554220/4
70'Camaro-Teal,Black Cloth,Cowl Hood, T/A spoiler,LS1+N2O, LS6 Stg2 heads, Futral Custom Cam, Victor Jr, etc, etc Up and Running!!!, Built TH350http://www.cardomain.com/ride/3069774
06 GSXR 750
Frum Roll Racing
Old 11-05-2008, 02:36 PM
Ravenous70's Avatar
this is my 1st LS1 car, a 1998 Trans Am on spray. On the juice it did 514rwhp, I am hoping to get more out of this Camaro when we go to the Juice http://www.cardomain.com/ride/554220
06 GSXR 750
Frum Roll Racing
Old 05-20-2009, 11:51 AM
Ravenous70's Avatar
well its been awhile so here I go
Installed C5 Front brakes and Calipers, smooth off the "Corvette" since its not one and put "Camaro" on it
Installed 98-02 Fbody rear brakes and calipers
Relocated rear shocks to road race style
Removed Gas tank and installed 16gal fuel Cell in trunk
Re-Routed rear exhaust to exit rear Valance
Coming soon is
Dash Bezel hydro dipped in Carbon Fiber in C6 style
Phantom white faced gauges to be recessed in Dash Bezel
dipped Carbon fiber lower door panels
dipped Carbon fiber front spoiler
Blue and White paint scheme
removal of LH8 oil pan, install Miloden pan
Lower front end
06 GSXR 750
Frum Roll Racing
Old 05-20-2009, 12:10 PM
awr68's Avatar
awr68 awr68 is offline
Progress is good!!
Tony
'68 Camaro
