Old 11-15-2008, 11:41 PM
Flash68's Avatar
Flash68 Flash68 is offline
Default Anyone heard of bead/sand blasting PP and flywheel?
Okay, I heard of an old racer's trick and wanted to see if any of you have heard of it or used it.
So apparently if you either bead blast or sand blast (not sure which one) your pressure plate and flywheel it can help the clutch seat much much quicker than say waiting for a 500 miles break-in. And apparently there isn't any bad side effects.
So, does this work?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 11-16-2008, 08:11 AM
It may break in faster but I don't think it will have as much bite. The smoother the surface is, the more area the clutch has to grab. Similar to brakes.
Old 11-16-2008, 02:45 PM
Flash68's Avatar
Hmm.. I would think if it was truly a "racer's trick" then the bite would be very important!
2014 4 tap Keezer
Old 11-16-2008, 05:03 PM
I can tell you after installing my clutch today....the flywheel is smooth as glass and the pressure plate is a little course.
Old 11-16-2008, 05:24 PM
Flash68's Avatar
You shoulda bead or sand blasted them both before installing so you could tell me if this trick works!
2014 4 tap Keezer
Old 11-16-2008, 05:26 PM
Well it works flawless so I don't mess with it. Just put the clutch in it and forget it. It's just not that fun pulling a tranny out on jack stands. haha
Old 11-16-2008, 05:37 PM
Flash68's Avatar
Yeah I am sure I won't try this "trick" unless I find 10 reputable guys saying it is a great thing to do. Just wondering if anyone else heard of it....
2014 4 tap Keezer
Old 11-17-2008, 03:44 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Just make shure you get the protective coating of the pressure plate.
Old 11-17-2008, 11:15 AM
Flash68's Avatar
So have you heard of/seen this trick done before?
2014 4 tap Keezer
