Old 11-22-2008, 10:00 PM
SPEEDSTREAM69 SPEEDSTREAM69 is offline
Default Help with LS2
Hello,
I am putting a LS2 in a 1971 Camaro, and was wondering if the front accessory drive system from a 2007 Trailblaser ss will work. I have found a great deal on the set-up but not sure if it will work.
any help would be great.
Old 11-23-2008, 05:52 AM
WILWAXU WILWAXU is offline
Won't work with a car style intake:
http://www.ls1tech.com/forums/9374707-post42.html
Lots of info on accessory drives here:
http://www.ls1tech.com/forums/conver...oem-parts.html
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 11-23-2008, 08:52 AM
z585's Avatar
z585 z585 is offline
What is the LS2 out of? I have a LS2 in my Trailblazer SS with the front accessory drive.
Just a thought.
Old 11-23-2008, 07:56 PM
Just a thought.
Your TBSS uses a truck intake, which is taller than car intake.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 11-23-2008, 09:41 PM
Hello,
My crate motor is corvette style, and it will be going in a 1971 Camaro.
looking at the images attached to the above link I think it will be a problem.
TB clearance on the shorter intake!. But I hope I am wrong cause the price is
really good.
Old 11-25-2008, 10:28 PM
Steve1968LS2's Avatar
Originally Posted by SPEEDSTREAM69 View Post
Hello,
Any LS2 drive system will bolt to any LS based engine... for example, I'm running an LS1 f-body drive system on my LS2.
Just make sure you have EVERYTHING the same.. from the balancer to the water pump.
Old 11-25-2008, 10:29 PM
Really? I wonder why.. I can't see how the intake affects the drive system.
Then again, I'm not an expert on truck drive systems. lol
Learn something new every day.
Old 11-25-2008, 10:33 PM
Hmmm.. I see the problem now.
But, having looked at the truck drive system it seems pretty unattractive. With so many junked Camaros and Vettes out there I would think you find one of their systems pretty cheap. Check Ebay?
Old 11-25-2008, 10:38 PM
Try Shaun over at SMC. Sometimes he has GM seconds and overstocks. It's were I get my stuff.
http://www.smcperformance.com/index.htm
