Old 11-27-2008, 05:25 PM
brans72 brans72 is offline
Question recomm a spot weld cutter old one broke
hey guy's i was using a spot weld cutter from the matco tool truck and it broke i would say quicker then i thought it should so i am loking for a new one. the old one was double sided with a niddle to center punch it and i think i can find better with your help. so i am asking you what would you recomm me to use for removing 1/4's to save the trunk. website or part #'s moe then welcome please help me out here guys!!! brandon
Old 11-28-2008, 06:48 AM
DOOM's Avatar
DOOM DOOM is offline
Brian
I use the Matco RB7KIT. This is all we use in my shop . A good long lasting cutter and you can get different sizes from 5/16 to 3/4 .. We drill a 1/8 makes it alot easier...
Mario
Old 11-28-2008, 08:16 AM
V8TV's Avatar
V8TV V8TV is offline
We run the Blair Rotabroach cutters... they cut like crazy, stay sharp, and make nice clean holes.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 11-28-2008, 09:36 AM
DOOM's Avatar
Yep I think Blair makes these for Matco!! They cut like crazy!
Old 11-30-2008, 05:51 AM
Joel145 Joel145 is offline
http://www.blairequipment.com/
Old 11-30-2008, 11:08 AM
Jim Nilsen's Avatar
Jim Nilsen Jim Nilsen is offline
When I was removing my quarters I trashed out the spot weld cutters I was using and in desperation to continue I took a 3/8 drill bit with the split point on it and went to the grinder and flattened out the cutting edge around the split point. It turned out that it lasted longer than the spot weld cutters I was buying. you get a hole in the center but I used that hole to weld from the backside where I could and the other places it didn't matter because you cover it.
