Old 11-28-2008, 12:06 AM
goob8869 goob8869 is offline
Default widest wheel for 67 Camaro
I have a 67 Camaro that I do not want to mini tub, and was wanting to know if I can fit a 19 or 20X10 wheel in the rear without doing this. I am also going to put a 4 link with a 9 inch Ford in it and was wanting to know how much I can shorten the rear end to get the fatest lip on the wheels.
Old 11-29-2008, 11:21 AM
EVS Motors Inc.'s Avatar
EVS Motors Inc. EVS Motors Inc. is offline
From my experience you can fit a 10" wide wheel in the back. A 275mm tire is the safest wide tire to run, but you can also fit a 285 with some fender rolling and trimming.
'97 Toyota Supra Turbo 950HP
'67 Chevrolet Camaro SS 1,000HP+
'69 Chevrolet Camaro SS 600HP
'69 Chevrolet Camaro RS/SS Twin Turbo
'04 Lamborghini Gallardo 540HP
'08 G55 AMG 500HP
'94 240SX 1,610HP
'95 Toyota Supra Turbo 1,300HP
Old 11-29-2008, 04:09 PM
67rstbkt 67rstbkt is offline
Probably a dumb question, but this would also be the widest for a 67 firebird? Also, I've been looking at some pics with the 275 rears, and they almost look like they stick out a little, is this how it is with this size? Or was the wrong backspacing used?
Old 11-29-2008, 05:05 PM
Call Frank he does a bunch of these
Old 11-29-2008, 09:37 PM
It sounds like the wrong offset/backspacing. We have a '67 and '69 Camaro with 10" wide wheels with 285mm tires in the rear and they don't stick out. We have done dozens of these fitments with no issues. A 275 is the perfect no issue size for stock cars with the correct offset/backspaced rear wheels. The fitment should be the same for a Firebird, since they are literally the same car.
'08 G55 AMG 500HP
'94 240SX 1,610HP
Old 11-30-2008, 11:32 PM
Do you know what the backspacing was on those wheels
Old 12-01-2008, 07:53 AM
18". 19". 20" is not the question, overall tire height and section width is all that matters. You need to stay with a tire package that is 25.5" to 27". Probably 27" on a 20" rim. If you want to tuck the wheel / tire package on a 67 / 68, your going to be pushing it with 10s. 9.5s pull the section width in a teenie and can make quite a difference.They say each 1/2" of rim is worth 3/10ths" of section, but at the 9.5" to 10.0" size on a 275, it is really close to a 1/2" of section for a 1/2" of wheel With 285s your really looking for trouble and alsmost certainly have to use 9.5 wheels
Frank Serafine
Old 12-01-2008, 01:27 PM
The OP mentioned narrowing the rear will that help him @ all?
Old 12-01-2008, 01:48 PM
No, The width of the rear really has nothing to do with how much tire you can get in there. you can only shove so much in the wheel well. The width of the rear really only changes how much lip you get on the wheel.
Just for example, say you need a 6" backspace on a stock width rear, and you end up with a 3" lip on a 10" wheels. If you narrow the rear 1 inch PER SIDE, you could reduce the backspace 1" and pick up 1" of outer lip for a 4" lip.
Or, say you mini tub and do not narrow the rear, you need a 8" back space and have a 3" outer lip. But if you narrow the rear 4 inches you can do a 6" backspace and get a deeper 5" outer lip
Frank Serafine
Old 12-01-2008, 11:34 PM
The only reason that I am asking about the rearend is to get a fatter lip not to fit them under the car. The only reason that I want 10 instead of 9.5 is because nobody makes 9.5 that have a flat lip. I would be fine with them if it wasnt for that.
