Old 12-01-2008, 06:03 PM
nvr2fst nvr2fst is offline
Default Suspension tuning
Okay guys. Heres one for ya. I had a quaffie unit installed into the stage 5 differential that RPM transmissions is setting up for me. My question is has anybody run one and had to retune thier suspension. I posted this over at LS1 tech and got some feedback on this matter that I wasnt aware of. What Im hearing is that upon bracking hard (track) the rear will want to feel loose until you punch the throttle again. Also if buy chance the inside wheel lifts on a turn all the power will go to the outside wheel causing spin out. Hopefully the chassis is set up for NO LIFT when that time comes. My reasons for the purchase (1) eliminates clutch packs all together (2) able to accelerate out of a corner quicker (3) power to the wheels will be optimized.
ANY THOUGHTS, or did I just waste 1500.00 for the Quaffie. Im being told that the driving aspects on the track (and maybe the street?)will be much different compared to my stock ZO6
Dave
Im not sure if this should be posted elsewhere
Old 12-06-2008, 10:06 PM
David Pozzi's Avatar
This is in a Z06?
Is it a gear type diff or what type exactly is it?
If you can manage to get the inside rear wheel in the air and be at full throttle, you are probably going to spin out no matter what type diff you have. It sounds like a guy who ran up on a curb on the track. I doubt you are going to have any kind of big problems. Most drivers naturally adapt to new handling traits a diff swap would create. Just work up to it don't go nuts the first lap and you'll do fine. It sounds like you are over thinking this, which is natural when you are waiting for the car to come back from the shop.
I drove a formula 5000 car that had a weisman diff, it locks on acceleration and unlocks when you lift off the gas, with a lurch to the left. After a short while, I didn't even notice it. I did have to have the front wheels pointed more straight when I got on it or it would understeer. Those cars have around 60% rear weight and huge rear tires, so rear traction out of corners is pretty huge compared to the front and understeer can happen more easily with a locker type diff.
David
http://www.PozziRacing.com
