Old 12-04-2008, 09:28 AM
chevy55 chevy55 is offline
Default Power sterring pump for front runner
Can anyone tell me what model and year vintage air uses for the power steering pump with the resevoir for their front runner system?
Chris
Old 12-04-2008, 10:00 AM
Steve1968LS2's Avatar
We just did that install on a 2nd gen a couple of issues ago in Camaro Performers.
It was a modern GM PS pump with attached black plastic tank. We picked it up from DSE.
In my notes it says a GM type II with a shaft OD of .664-inch.
Old 12-04-2008, 10:16 AM
Blown353 Blown353 is offline
I believe an original application is from a mid-80's Pontiac Sunbird.
1969 Chevelle
Old 12-04-2008, 11:16 AM
Thanks, I was hoping to find one today from the local dealership.
Old 12-04-2008, 11:20 AM
Thanks, had them look up an 85 Sunbird but it has a remote reservoir.
Old 12-04-2008, 11:26 AM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
A company called "Turn One" can also supply you with a specific pump. They Supply cup cars and nascar but are price competative. Getting a pump with both the correct shaft diameter and resivoir to work with the Front Runner assembly is key. DSE has a hard line the cleans up the plumbing greatly on the preasure side. The FR bracket makes it tuff to install a preasure line with a conventional fitting.
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 12-04-2008, 11:38 AM
tumper93 tumper93 is offline
A Cadillac Deville or Seville with the Northstar uses the attached reservoir so do 2000 Cavaliers
Old 12-05-2008, 05:47 PM
69CamaroPT 69CamaroPT is offline
I got mine from DSE.
http://www.detroitspeed.com/productp...ring6769cf.htm
69 Camaro
67 GTO vert
