Old 12-04-2008, 07:16 PM
Blown353 Blown353 is offline
Default CSI starter, MSD Distrib, Procharger bypass valves, Timing Cover, etc.
Here's the next wave of parts from my SBC selloff as I go LSx...
All prices include shipping.
I'm near Sacramento, CA.
PM with questions/offers/"I'll take it."
Comp 314 HR hydraulic roller cam for SBC, catalog grind #12-470-8. About 2000 miles on it. Ground on a -9 billet core with a pressed on iron distributor gear for long life on the street (no need for a bronze gear.) 252/252 @ .050, .600/.600, 110 LSA. NASTY idle in a 406 and ran very well. Putting a Procharger on this engine so this cam goes bye-bye.
$150
Comp hydraulic roller cam for turbo'd SBC, custom ground. 242/242 @ .050, .540/.540 lift, 115.5 LSA. Brand new in box, never installed. Ground on a -9 billet core with a pressed on iron distributor gear for long life on the street (no need for a bronze gear.)
$225
CSI Hitachi ministarter for 153T or 168T flexplates. This sucker has been a trooper. Unlike many mini-starters, this one has a genuine Hitachi motor. Great condition, no wear or chips on the gear teeth.
$145
MSD 85501 slip collar distributor. Locked out, no advance provisions. Comes with GM Melonized gear on it, but also a new bronze gear. Spare rotor included. Currently has 60 degrees of lead on the reluctor with the rotor aligned with the cap terminals at 30 degrees for use with an IPU triggered EFI box like an Accel or FAST, but if you want I can rephase it to 0 degrees as it came from MSD.
SOLD
Old-style Procharger Pro-Flow bypass valve.
$50
1969 Chevelle
Old 12-04-2008, 07:19 PM
New style billet Procharger Pro-Flow bypass valve.
SOLD
Made for You wire looms for 7/8mm wires.
$20
Cast aluminum SBC timing cover.
$25
Be-cool fan switches-- on 195F, off 180F.
SOLD
1969 Chevelle
Old 12-05-2008, 12:37 AM
Pm Sent!
63 Z06
Old 12-12-2008, 07:41 AM
Updated:
Added 1 more camshaft.
Be-cool fan switches sold.
MSD Distributor sold.
1969 Chevelle
Old 12-28-2008, 07:18 PM
Bump.
1969 Chevelle
