Old 12-07-2008, 11:09 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Default What media do you use in your blast cabnet!
Just curious what everyone likes the best. I want to find what cuts the fastest and removes rust but does little to no damage to the base metal?
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 12-09-2008, 06:37 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default media
I have silicon carbide in mine use it to clean up metal - like diff yokes, its pretty harsh. it depends on what kind of metal your cleaning. I dont blast alot of stuff but an older buddy used to do lots of aluminum intake manifolds with actual glass beads - they have several grades after doing thefirst blast he would change the glass and vacuum it out-put in new glass and blast again- the final surface looked really sweet. so try out different ritueals it just depends how nice you want it to look.
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 12-11-2008, 09:18 PM
badmatt's Avatar
badmatt badmatt is offline
glass bead, works well on everything!
Old 12-12-2008, 05:29 PM
HaulinAsp's Avatar
HaulinAsp HaulinAsp is offline
Exactly what parts are you blasting? A better answer can be given if we know what you are needing to blast.
I use
Black Beauty
Regular sifted play sand
Glass Beads
Walnut Shells
2004 Ram SRT-10/Cummins Conversion- Project RattleSnake
1966 Dodge Charger- Viper Powered Project
Old 12-20-2008, 08:31 PM
We use #80 glass bead for all the standard steel blasting (hubs, drums, driveshafts, all the small metal parts and bolts/nuts.)
Check the Eastwood site for a quick list of recommended media for a specific metal. I'm sure there are several lists out here on the web with good info.
Good luck, Jim
Old 01-13-2009, 08:27 PM
Streetwerkz's Avatar
Streetwerkz Streetwerkz is offline
glass bead leaves residue behind, and is not recommended for anything that will be painted, or powder coated.
We blast all day, every day in preparation for one type of finish or anther, and we use aluminum oxide.
does not build heat, distort sheet metal, and removes faster than glass bead, black beauty, ect.
blast sheet metal at 40 psi no higher ( profile the material to much )
anything above 16 GA, 70 psi is fine
just my 2 cents
www.STREETWERKZ.com
Custom Powder Coating, and Media Blasting
