Old 12-13-2008, 07:17 PM
mike23109 mike23109 is offline
Thumbs down Painless Fuse Block
Has anyone wired one of Painless Performance's 30003 fuseblock to a 1970 Chevelle, or similar A body? I generally able to follow the instructions, however, I'm having a little difficulty wiring the ignition. I have a wiring diagram but it is a little difficult to follow because I am unsure of what each individual wire does.
Old 12-14-2008, 07:06 PM
chicane's Avatar
chicane chicane is offline
What part are you having difficulty with... ?? Are your instructions complete... ??
I see that on page seven (7) that you need to describe what ignition that you are going to use to determine which wiring option would be correct. Are you using a stock or aftermarket ignition system... ??
Thus far... wire 920, pink (14ga) goes to the ballast and then to the coil. Or... you can run off of the "I" terminal of the starter solenoid to the coil.
Painless Wiring 30003 instructions
Also... if you dont own the GM manuals (Assembly, Fisher Body... etc) swing by the Library with a hand full of change. You can make copies of the OE wiring diagrams for next to nothing. It will give your terminal numbers for break out and OE color codes for the original wiring.
Old 12-16-2008, 06:07 AM
Thanks for the info. I do have all of the instructions and a wiring diagram. I'm just not that good with the electrical thing. I sorta get it, it's just a steep learning curve for me.
