Old 12-16-2008, 03:43 PM
rallye455 rallye455 is offline
Default 2000 Tahoe Brake bleeding Question
I have a dumb question about the brakes on my tow vehicle (2000 Tahoe). Today I changed the rotors, pads and calipers on the front of my Tahoe and then bled all 4 brakes till there was no air present in the bleeder line but I dont have a pedal when the truck is running. Is there something special that needs to be done with the ABS or ??????? I'm at a loss....hopefully someone has had this same problem and can point me in the right direction.
Old 12-16-2008, 04:06 PM
Must not have got all the air out of the fronts. Not usually any special bleeding sequence with ABS unless you are replacing the ABS unit.
Old 12-16-2008, 05:13 PM
zcrz zcrz is offline
I agree, must have air somewhere...
Old 12-16-2008, 05:16 PM
Do you think I still need to bleed all 4 or should I be able to get away with just doing the fronts? I know nothing about ABS systems. I thought maybe there was something else I needed to do.
Old 12-16-2008, 05:20 PM
68protouring454's Avatar
sometimes the proportion valve will close or partially close when the system feels a big loss, because most of the newer stuff in a single reservoir. sometimes i have needed to leave bleeders open and hit brake pedal like a panic stop to open it back up.
i was Leary after being told that by the gm dealer, but it worked, it was either that or a new prop valve.
this was on a 98 3/4 ton chevy truck
Jake's Rod Shop
Old 12-25-2008, 06:50 PM
elitecustombody's Avatar
make sure your calipers were installed on the proper side,and the bleeder valve is pointing up, you could have left caliper on right side and the right caliper on left, you'd never be able to bleed the air out
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
