Old 12-16-2008, 06:20 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Default How do you remove the center gauge cluster for a 67 camaro?
This seems so stupid, but how do you remove the center gauge cluster for the speedo and tach on the 67 camaros? It doesn't seem to want to pop out. I need to change the bulbs back there and get rid of the blue bulbs that don't work worth a damn. Is there some trick to it?
Old 12-16-2008, 06:41 PM
68protouring454's Avatar
lower steering column, its sucks to think about doing it but takes about 2 mins, 3-9/16 nuts, and it lowers down
Jake's Rod Shop
Old 12-16-2008, 07:00 PM
mazspeed's Avatar
The 2 large nuts? Just pop those out, lower the column, and does this allow the gauge cluster to come out, or just to get enough room to put my hand in there? Thanks again Jake.
Old 12-16-2008, 07:08 PM
pull it right out, usually
yeah there should be 3 nuts, 2 across from each other, and one back alittle and higher up, you will see, column will go loose when you have them out
Jake's Rod Shop
Old 12-16-2008, 07:30 PM
mazspeed's Avatar
Cool Jake thanks again.
