Old 12-17-2008, 06:39 AM
fabricatordave fabricatordave is offline
Default looking for 76 nova frame dimension chart
i have a 76 nova subframe that looks bent looking for dimensions so i can see how messed up it is
Old 12-19-2008, 01:05 AM
astroracer astroracer is offline
Any good body shop that does frame work should have repair manuals with everything you'll need. Maybe if you ask nice they would let you copy them.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 12-19-2008, 01:10 AM
deuce_454's Avatar
well one thisn that is true for all frames is that everything should be paralell side to side (if one side is level, so should the other be) and all cross measurements should be the same.. (and if it looks bent it usually is)
Jake: Hit it.
