Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 12-18-2008, 04:11 PM
ferk_0331 ferk_0331 is offline
Default Any info about CPP a arms
Has anyone used the CPP tubular a arms on a 67-72 c10 and how did you like them. I'm thinking of using them and their 13" or 14" modular spindle disc brake kit. The truck will mostly be used for a spirited dd.
Old 12-19-2008, 08:43 AM
Jr's Avatar
Jr Jr is offline
What are your plans for the truck? Do you want it lowered? What kind of motor are you going to run?
Old 12-22-2008, 08:07 AM
It will be a daily driver with a 350 horse small block until I can afford a ls conversion. I am running it with a 2/3 drop. The truck weights in at around 3800 lbs but the target weight is about 3300-3400lbs.
Old 12-22-2008, 09:47 AM
Jr's Avatar
Jr Jr is offline
Do you plan on going lower? There is no need for 13" or 14" brakes with these trucks. I would look into air ride, early classic enterprise(ECE), or hotchiks.
I will never use cpp again.
