Old 12-27-2008, 06:29 PM
Default wrecked low mileage C5 $10k obo
The entire car is for sale as a whole only. Do not call dibs or even ask about parts as nothing but the car is available right now.
On to the good stuff.
Here's what the car looked like before a truck drove over the front end.
Here's what it looks like now
The good is that the car is in excellent condition aside from the front end. The interior is virtually perfect. The engine has 23k on it and has a small cam. Transmission is an M6. Car is fully loaded as well. I believe a tinted driver's side mirror is the only option the car did not have.
This car was our show car that we built back in 2002. It was very meticulously maintained. Always garaged and covered inside often too. The only times is ever sat outside were for out of town shows/cruises and now that the front end has been ripped off. It was covered every night it was not in a garage and is still covered now. Car was not beat on relentlessly either.
The frame is obviously pushed to the driver's side. The suspension is not damaged. The truck hit in front of the passenger tire. This was a low speed crash too. Personally, I'm amazed that the truck destroyed the front end like this since the vette was stopped before he drove over it. Everything from the firewall back body wise is great including the glass. A few lights on the front end survived but everything else was cracked and broken.
You do not get the exhaust system, supercharger, or brake rotors. We have an 03 that everything will be transferred over to. That means that if you want a factory exhaust system minus mufflers, we'll have a low mileage 03 system for you(it's the same as the 02). Low mileage blank rotors will be on the car too. You do get the center console. It was removed to remove the Hurst shifter. There's no reason for us to put it back in place but it goes with the car. You will get the cam and springs that are in the engine. If you want an LS6 intake and throttle body, that can be negotiated. Otherwise, no intake. The engine will make a little over 400hp with the cam that is in there and the appropriate supporting mods. No other modifications where done to the engine. Heads were never off the block.
We are hoping someone is interested in the whole car to be fixed or if you want to part it, have at it.
Asking $10k obo. Please contact me if you have any questions or want more pictures or want to negotiate. We'd really like to move the car as a whole instead of part it ourselves.
Old 12-27-2008, 10:32 PM
SWAPMEETCRAZY's Avatar
SWAPMEETCRAZY SWAPMEETCRAZY is offline
Were are u located?? thanx jim
Old 12-28-2008, 06:31 PM
geeze I completely forgot that part. The car is in Social Circle GA which is about 50 minutes East of Atlanta on I20
