Old 12-28-2008, 07:31 AM
uk68327's Avatar
uk68327 uk68327 is offline
Question Muncie or Super T10
Hi All,
Anyone here running one of the above with a gearvendors underdrive/overdrive unit? If so, what's it like/how does it work? would you recommend the combo or go for a TKO tranny?
Happy New Year to all
Cheers,
Mark
Mark
'68 Camaro
'93 Golf Rallye
Old 12-28-2008, 05:08 PM
countryboy countryboy is offline
I have a super 10 with an extreemly wide ratio that works for me, but I do have a gear-venders on another trans and its pretty cool. it locks up rather quick and is like driving an old truck with a two-speed except you don't have to sync the gears your self. I personally like them better with an autosmackit(automatic) though. It will let you play around with the rear gears to get a more practical setup.
Old 12-30-2008, 01:27 PM
yoboy sawyer's Avatar
yoboy sawyer yoboy sawyer is offline
so is the super t -10 a wide ratio than a saganaw
Old 01-08-2009, 08:37 PM
Well when dealing with a t-10 you gotta look at the codes. I don't remember where they are located but a little searching on the net should help. You should find the code meanings with it.
I have a bb code which is a very wide ratio!
