Old 12-29-2008, 02:58 PM
deuce_454's Avatar
Default fabricated LSx swap pan....
look what i found surfing for stuff: http://www.champpans.com/index.cfm?e...tdetail&id=194
Jake: Hit it.
Old 12-30-2008, 12:28 AM
jannes_z-28's Avatar
GM has in its new GMPP catalog on page 221 a LSx oilpan made to fit conversions in to older US cars.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 12-30-2008, 03:39 AM
brans72 brans72 is offline
that champ pan is same people i do believe that makes the pan for autokraft.i looked into them once but i supported a sponsor here and got a discount. thanks again kurt from autokraft.
Old 12-30-2008, 04:51 AM
deuce_454's Avatar
that autocraft unit is nice too.... im all for supporting the sponsors here on lat G so ill go for the autocraft unit if my attempts to modify my f-body one fails
the autocraft unit looks like its steel??
Jake: Hit it.
Old 12-30-2008, 09:30 PM
Blown353 Blown353 is offline
The Autokraft pan is steel, I have one out in the garage. Nice pan, a little extra capacity because of the kickouts, and the ability to run a stock location filter. What I don't like about it is no provision for an oil temp sender or turbo drainbacks, but Kurt at Autokraft is very willing to work with you to add them and then replate the pan.
Champ makes the same pan you posted in steel also, for $200 less.
All that being said, as far as fab quality goes I haven't seen any nicer quality LSX swap pan than the ATS pan.
1969 Chevelle
Old 12-31-2008, 07:31 AM
deuce_454's Avatar
this one sure looks nice...
http://www.champpans.com/index.cfm?e...tdetail&id=193
i have bought enough stuff from tyler that i think he wont mind if i get the above one.. especially since his LSx pan i on backorder...
Jake: Hit it.
Old 12-31-2008, 09:17 AM
67ragtp 67ragtp is offline
Any idea if that champ pan will clear a 400 to 427 stroke?
Rich
Old 12-31-2008, 09:20 AM
itsals1 itsals1 is offline
The Autokraft pan includes a oil pick-up and billet oil filter adapter which is not included in the price of the Champ Pan. The Autokraft pan also has nocthed corners for tie rod clearense.
Old 01-01-2009, 06:16 AM
deuce_454's Avatar
looks like the ticket is the autocraft one.... as it comes with both pickup and filter adapter, and is notched... not sure the square champ one clears my frame.. also the ATS pan requires a remote filter adding to the price
Jake: Hit it.
