Old 01-04-2009, 12:06 PM
Default Need help to identify a spindle
I have a customer with a take over project with a custom frame under the car. The builder / chassis builder is out of business / MIA and we are trying to help my customer finish the car. I am trying to indentify this spindle and I thought it was going to be Mustang 2 but it is not.
Can anyone tell me what it is? I will give a $25 gift certificate to GPSuperStore to the first one to answer correctly.
Frank Serafine
Old 01-04-2009, 01:13 PM
deuce_454's Avatar
not sure, but the caliper mounting looks very very mustang 2 ish... i would say its an aftermatket dropped mustang 2 unit....
edit... perhaps i should read the whole post before answering....
Jake: Hit it.
Old 01-04-2009, 02:23 PM
HRBS's Avatar
HRBS HRBS is offline
I agree with deuce. It looks like a mustang 2 spindle.
Try MBM. They not only have a spindle that looks like that but the part number is 156 (same as the casting in your pic).
They are a universal dropped spindle that alot of garage rod builders use.
Worth a try.
http://www.mbmbrakeboosters.com/Spindles.html
HRBS on Facebook
Old 01-04-2009, 02:39 PM
I have the customer seeing if the other side ends in 155, if so I believe Steve is the winner! I will also call MBM tomorrow to verify all the numbers.
Frank Serafine
Old 01-04-2009, 04:45 PM
Ding, Ding, Ding, We have a winner. The other spindle has 155 on it and head on looks eactly like the one pictured.
Thanks Steve.
Frank Serafine
Old 01-04-2009, 04:47 PM
HRBS's Avatar
No problem Frank
HRBS on Facebook
Old 01-04-2009, 06:25 PM
Scotts Hotrods Scotts Hotrods is offline
Supporting Vendor
The pic of the spindal is a two inch dropped spindal based
off a mustang two.The spindal is from hill creek manufacturing, and international wholesale out of
nebraska sells that spindal.
Hill creek is ut of nc.
Justin
www.scottshotrods
Old 01-05-2009, 01:46 AM
Thanks Justin,
So I assume it takes a standard Mustang 2 brake kit?
Frank Serafine
Old 01-05-2009, 10:08 AM
Supporting Vendor
Originally Posted by ProdigyCustoms View Post
Thanks Justin,
If you are going to use stock brakes on the spindal.We have
a front basic kit that we sell for $329.00.
Our kit comes with
1.11 inch rotor your choice of chevy or ford bolt pattern
2.82-91 chevy s-10 caliper loaded
3.inner and outer races and bearings, spindal nuts etc
4.Scotts caliper bracket and all hardware.
5.We can sell our braided brake lines with the banjo bolts $59.00
So hope this helps you out.
Justin
Old 01-06-2009, 11:10 PM
terryr terryr is offline
I can see why they went broke. Upper balljoints stressed out, tie rod cotterpin ABOVE the nut, and the overall geometry looks kind of crappy.
BitsOfTech
