Old 01-09-2009, 12:33 AM
Dougs67camaro's Avatar
Dougs67camaro Dougs67camaro is offline
Default F/S. Complete carbureted induction system and ignition system.
Well guys i'm switching over to efi after spending a ton of money on my carbureted induction. The stuff i am listing has less than 100 miles on them all. I will list all the parts and then list the links in the same order to summit racing where i bought all the stuff. I will attatch some pictures of the stuff as it is now, on the car. I will take the parts of and get better pictures of each part if someone is interested. Keep in mind the parts all have less than 100 miles on them so they are all like new! I added up the total is over 1600.00 that i paid and the stuff is like new. This is everything you need for a fuel system going from your stock on body fuel line up and the complete ignition system. I will take 1100.00 for it all. Will not seperate at this time unless i see interest in most of the parts and then we can talk. Sorry about the poor pictures, they are from my camera phone. I can get any pictures you want when my wife helps me out with her digital camera. This could get lengthy so i'm sorry ahead of time.
1. Pro Systems 688 cfm mechanical carb with annular boosters. I have the spec sheet if any info is needed. The carb has a 750 body, but is rated at 688 due to the larger boosters. Carb works awesome! Cost 712.00. Will atatch a picture of the spec sheet.
2. Edelbrock pefromer rpm air gap manifold(Vortec style).Part #7516.
http://store.summitracing.com/partde...6&autoview=sku
3. Summit phenolic(wood) 1/2 inch spacer. Part #sum-g1405-1.
http://store.summitracing.com/partde...5&autoview=sku
4. Arp carb stud kit. Part #ARP-200-2403.
5. Msd ready to run distributor w/bronze or iron gear(has bronze gear on it now but have a new iron gear). Part #MSD-8360. The bronze gear was an extra 40.00.
6. Holley mechanical fuel pump 7.5 psi 80 gph. Part #HLY-12-834. Will include fuel pump rod, fuel pump cover plate and bolts.
7. Assembled braided -6 hose with an fitings from pump to carb.
Varios an fittings and 3foot of line was 40.00.
8. Summit alluminum fuel filter. Comes apart so you can clean it. Part # SUM-230106.
9. Proform Air cleaner assembly with 4 inch filter. Will include stud and adapter to fit various carbs. Part #PRO-141-693.
10. Summit -8 braided carb fuel line kit. Part #SUM-220100N.
11. Msd blaster 2 coil. Part #MSD-8202.
12. Coil bracket .Part # TRD-9366.
Old 01-10-2009, 06:50 PM
Close thread please. Thanks
