Old 01-09-2009, 06:50 PM
monmon030791 monmon030791 is offline
Default How to install the turbo 350 kickdown cable
How!?!?!
Old 01-09-2009, 07:00 PM
which end, carb or trans? Is this a remove and replace on a car that has an existing cable? What carb?
on the carb i just dont know how the mechanism works!
Old 01-09-2009, 07:04 PM
You just mount it and then connect the cable to the carb linkage. There's no adjustments if you're using a factory carb, linkages, and brackets. What car are you working on?
Old 01-09-2009, 07:17 PM
1969 camaro baaaaaaaaaabyyyyyyyyyyyy! but were would I mount it i have like no were to mount it, threads are to short for me to mount it on the back of the carb. no were else to mount in the distributor is in the way. ahhh!
Old 01-10-2009, 05:02 AM
907rs's Avatar
907rs 907rs is offline
Google is your friend.
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
Bill
Old 01-10-2009, 05:15 PM
did you just purchase this car? It sounds as if something is missing. If you click on the google link you can see that there's a bracket on the intake that can hold the kickdown cable. However, Holley and Edelbrock both make brackets that mount of one of the carb stud that allow you to mount the kick down. What carb do you have? Or better yet, any luck getting it figured out?
