Old 01-13-2009, 06:04 PM
Travis77's Avatar
Travis77 Travis77 is offline
Default Fab 9 housing
Anyone here selling them. A local shop quoted me $1250 complete with ends, bearings, and axles. How does that price compare? I have not had the chance to sit down and make calls. Thanks
67 Fastback 418, hogans upper, FAST efi, Richmond 6spd, global west front, homebrew 3-link, mini tubbed, baer brakes with hydroboost, pilot sports on Ze Boost wheels
Old 01-13-2009, 07:47 PM
tobenk tobenk is offline
Default Fab 9
Thats not to bad of a price if that inculdes fab everthing up and axles.
Heres is a pic of mine. Attachment 15352
Attachment 15353
Old 01-14-2009, 04:13 AM
Travis77's Avatar
That includes everything but brackets. I have seen that picture before. I have it saved in my favorites. You going to be running a 4 link?
Old 01-14-2009, 02:56 PM
We would be happy to work with you on the Fab9 from Chassisworks. I'm sure if we are pricing apples to apples with your previous quote we can either match it or do better. It will depend on the specifics. If you would like, email me with the specs and we can go from there and better help you get the parts you need.
[email protected]
Old 01-14-2009, 09:52 PM
Default Fab 9
Yes i am going to run the chassisworks prostreet 4 link. Heres is a pic of the back half. Attachment 15366
Attachment 15367
Old 01-15-2009, 05:17 AM
deuce_454's Avatar
there are a couple of vendors that are chassisworks dealers, the only one i knew of was SC&C but as it would appear above, Drivers inc is also in the game... have only had good experience with SC&C and only heard good things about Drivers.... so its a question of who is closest, and your personal preference..
I have talked to markus at SC&C about Fab 9 on another occation and as i understand it you really need to be sure what you want, as the housing is built to your specs, so be sure you know exactly what dimensions you need..
If you want some assistance in the geometry department i can personally vouch for marcus at sc&c ... but i cant say that drivers inc arent suspension geometry gurus as well...
hope it helped alittle
Jake: Hit it.
Old 01-15-2009, 08:23 AM
abadsvt's Avatar
abadsvt abadsvt is offline
Sorry for the ignorance and i don't mean to hijack the thread but i was curious what is the advantages to going with a fab9 rear end? I love the way they look but wasn't sure. So does it take 12bolt stuff or ford 9"? What about axles? I don't have it in my budget but maybe the next build. again sorry for the hijack.
Josh
Old 01-15-2009, 10:05 AM
deuce_454's Avatar
its a fabricated 9 inch ford housing... "fab9" and it accepts: well 9 inch components... that being said, you can just as easily stuff a 12 bolt diff and ring/pinion in there if you use a strange engineering 12 bolt drop out centersection, just be sure to order the axles with 9 inch ford axleends.... the advantages o fthis is the reduced drag and weight of that unit...
Jake: Hit it.
Old 01-15-2009, 12:02 PM
Travis77's Avatar
Default Sc&c
Sc&c would help in the geometry aspect of building a 3link, or coming up with the measurements on the housing itself?
Old 01-15-2009, 12:41 PM
deuce_454's Avatar
with regards to the 3 link question im prety sure the answer is yes... with regards to the measurements on the housing i am equally sure thet marcus would want you to supply some of the measurements to be sure that it fit.... but give him a call, he has experience designing 3 links... im just waiting for him to market the latest one
Jake: Hit it.
