Old 01-15-2009, 11:28 AM
Reckley's Avatar
Reckley Reckley is offline
Default Small Block Chevy 350 “turn Key Engine”
We have for sale a freshly built engine that has never been in a car. It has recently been assembled and will be tested on an engine test stand. If you are interested I can send pictures or a video of the engine running on the stand. If you are local to me, you are more than welcome to come by and see it run and discuss how we built it.
If you are not local I am willing to assist with shipping however, the buyer pays any shipping costs.
The engine is located in Warren, MI. If you have any questions I can be reached at 248-892-2292. I can also put you in touch with the builder who can answer any tech questions as well.
This is a great deal for someone who needs a turn key engine.
Price $3000.
Cylinder Block- Mid 1970’s 4 bolt main block.
Cylinder Heads- Dart iron eagle 2.02 valves
Crankshaft- Stock nodular iron reground.
Pistons and Wrist Pins- New hypereutectic .030 over.
Rings- New chrome Sealed Power.
Oil pump- New Melling BB pump fpr SB.
Rods- Stock 350, resized with ARP bolts.
Camshaft-New Comp cams flat tappet No. CS XE268H-10.
Cam bearings- New Sealed Power.
Lifters- New Comp Cams hyd.
Rocker arms- Aluminum roller.
Push rods- Chrome Moly.
Valve springs- New Comp Cams.
Retainers- New Comp Cams steel.
Valve Locks-New Comp Cams single groove.
Bearings- New Clevite 77.
Gaskets- New Fel Pro.
Timing Chain- Double roller.
Intake- Edelbrock.
Damper- New 8 inch.
Oil pan, valve covers, air filter and front cover- chrome.
Carb- Edelbrock 750. with heat spacer.
Distributor and coil- MSD.
Starter- Stock GM.
Alternator- Bosch.
Water pump- Long SB Chev.
Pulleys- Damper and water pump.
Flex fan
Engine features
Rotating assy. balanced.
0 deck for unleaded premium fuel.
9.8 to 1 Compression.
Camshaft degreed.
Damper timing tag degreed.
Est. HP 375
Engine run in on test stand.
All clearances verified.
Block. Heads etc. Glass bead blasted.
New brass freeze plugs.
All new threaded and cup plugs.
Old 01-24-2009, 02:09 PM
Reckley's Avatar
Price lowered to $3000!! If you need an engine for spring this one's ready to go.
I also have an air cleaner and fan that are also included.
Mike
