Old 01-20-2009, 11:05 PM
snowskater6996's Avatar
snowskater6996 snowskater6996 is offline
Default differential dicision
I have a mopar 8 3/4 and was looking for a new differential for my challenger project. Im looking for something streetable but will put the power to the ground when needed. I have no clue whats in it now but it seems like a spool since it screetches like no other going around sharp turns, especially at slow speeds like in a parking lot. Seeing if you guys have any suggestions. Thanks
Old 01-21-2009, 04:28 AM
We were top 10 in Moser sales last year, so we have a little experiance with rear ends. If I were doing a Mopar, it would have to be a Dana 60 with a 35 spline Tru Track. Baddest / strongest G Machine rear you can buy. Stronger then you will need it and there will be none of the squeling stuff in hard turns with a Tru Track. And we have them priced very resonable. Depending on what type of brackets you need on it, what options we select, and where you live, your looking at anywhere from $2000 for a base unit to $2500 for the mackdaddy set up to your door.
Frank Serafine
