Old 01-21-2009, 09:21 AM
69496 69496 is offline
Default 496 big block
I have a 496 engine that I am considering to sell. Engine is profesionally built and never even installed. I want to change over to an LS motor for my project.
genVI 454 4 bolt main block
eagle rotating assembly rated to 1000hp
JE pistons 11.2-1 compression
comp cams solid roller camshaft, rouglhy 248 @ .50 and 650 lift
edlebrock performer RPM heads fully ported
Anyone interested out their.
I also have a,
1) 396 chevy from a 69 SS chevelle,
2) Big Block LS6 heads fully ported
3) oval port passenger car heads, port matched
4) performer RPM oval port intake manifold, port matched
5) Crane full roller rocker arms 1.7 ratio
6) 12 bolt posi for A-body, 3.73 gears
7) 12 bolt posi second gen F-body, 3.73 gears and disc brakes
8) Turbo 400 transmission, shift kit, manual valve 2400 and 3000 stall
9) 15x10 rally wheels, 5" backspace and 295/50 BFG tires
Trying to clean out and make some money for my chevelle project.
Old 01-21-2009, 09:41 AM
6D9 6D9 is offline
Price???
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 01-21-2009, 10:28 AM
Prices would of been good I guess.
1) As it sits right now the 496 short block is assembled and ready to go less camshaft. I am looking for 3000 for the short block.
2) The edlebrock heads are new and never run. I have the valves but no springs and they are unported right now for 1000.
3) The performer RPM oval port intake manifold is port matched and I am lookng for 150
4) The Turbo 400 trans has been out for a while but ran great when I took it out. I would like 300 for the trans and 100 for each torque converter (2400 and 3000 stall)
5) The rocker arms are the crane cast aluminum with 1.7 ratio, 75 dollars
6) The A-body rearend is a 12 bolt posi 3.73 gears and used, 750 dollars
7) The f-body rearend is a 12-bolt posi, 3.73 gears and rebuilt with disc brakes for 1500.
8) The 396 short block is complete and in good shape but used, looking for 750 dollars.
9) The oval port passenger heads are complete, used and pocket ported, looking for 500.
10) The LS6 big block heads are complete and fully ported for 800.
11) 15 x 10 rally wheels, 5" backspace with almost new 295/50 tires for 200.
Old 01-21-2009, 10:41 AM
6D9 6D9 is offline
So Im guessing you dont want the carb now right??
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 01-21-2009, 03:48 PM
Sorry probably won't need the carb. And some more info. The 496 short block was built by the former chief engine builder for Banks Engineering who started his own shop called BMS. Great guy and great shop.
Old 01-25-2009, 08:03 PM
ulySSes ulySSes is offline
Are the wheels SS rallys? Where are you located?
'69 Chevelle SS396- Blk on Blk
Old 01-25-2009, 08:26 PM
They are corvette style rallye wheels and I am located in Corona, California
