Old 01-27-2009, 07:16 PM
KPC67's Avatar
KPC67 KPC67 is offline
Default Dynacorn vs Goodmark
Hey guy's, Is it true that Dynacorn sheet metal for a first gen camaro fits better than Goodmarks?
Kevin Carter
Old 01-27-2009, 07:28 PM
ironworks's Avatar
I have noting but problems with Goodmark. The only dynacorn quarter we have done fit great. I will never use Goodmark again.
Rodger
Old 01-27-2009, 07:36 PM
KPC67's Avatar
Yeah, i heard they were different. Supposedly Goodmark is not registered with GM since Dynacorn started producing their bodys. I have Goodmark quarters for my 67 camaro and they do not fit well. I was considering buying a pair from dynacorn to see how they fit. Now don't let this rub off the wrong way, I know they are both aftermarket and could possibly need some work.
Kevin Carter
Old 01-27-2009, 08:52 PM
SWAPMEETCRAZY's Avatar
SWAPMEETCRAZY SWAPMEETCRAZY is offline
Rodger
C10 goodmark bedsides are good but doors are junk-not sure if dynacorn makes c10 parts--jim
Old 01-27-2009, 09:04 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
From what I hear, Goodmark sells the Golden Legion panel. They (Goodmark) don't produce their own panels. I used a Golden Legion panel for my driver side, and it fit like a glove. I just test fitted my passenger side quarter, and can't say the same about it. Actually, I'm trying to ship it back and try another one! Not really sure how it passed QC.
Chris
Old 01-27-2009, 09:17 PM
good luck!! i had a good "goodmark" drivers door gut tried 3 pass. doors--sent all back--lucky to have a good friend in business--found some good used ones!!
all c10 stuff though!!! jim
Old 01-27-2009, 10:16 PM
Musclerodz's Avatar
Dynacorn has truck parts. They even make new 47-54 cabs. I have noticed what may fit great from Goodmark (Golden Legion), may not fit with Dynacorn, or vice versa. I use both, some parts fit equally well, others are worth the metal they are stamped out of. We have also used EMI, which is stamped here in the US. More expensive yes, but they are worth every penny. The only issue with EMI is they stay away from most parts already duplicated by someone else
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-27-2009, 10:33 PM
Thanx Mike--that's what i love about this site--always learning and sharing !! jim
Old 01-30-2009, 08:29 PM
vicious69's Avatar
vicious69 vicious69 is offline
I heard that both the Goodmark panels and the Dynacorn panels are stamped out in the same factory in China? I used Goodmark sheet metal on my 69 Camaro and it required some tweeking to say the least .
Scott aka vicious69
1969 camaro pace car Z11
1969 Camaro X44 Pro Touring 383 6spd
1967 Chevelle Resto Mod LS2
Old 01-30-2009, 09:17 PM
Musclerodz's Avatar
I know Goodmark has changed some tooling. Some stuff definitely used to have problems. I think BOS hung Goodmark on Penny and everything seemed fined according to Steve if I remember the post correctly after the accident. I also know there are some Dynacorn pieces I wouldn't bother with either. I think both comapnies are hit and miss depending on what part it is.
Mike Redpath
facebook page
