Old 01-31-2009, 04:46 PM
catmull catmull is offline
Default Lq9
why dont more people use the lq9 engine in there fbody? they are a lot cheaper and they make good horse power. is there a reason? if anyone knows please tell me
Old 02-01-2009, 05:46 AM
zcrz zcrz is offline
i've been thinking the same thing...seems the prices are decent.
Old 02-01-2009, 01:52 PM
chicane's Avatar
chicane chicane is offline
Well... weight is an answer to that question.
Not to mention that an LQ9 long block runs right about $4300-4500... and a complete crate LS2 runs right around $5500. After you get a manifold, injectors, coils, fuel rails... etc etc... your are right at the same as an LS2, or even a little more. Also not to forget, that the LS2 makes more power right out of the crate.
Anyway you look at it... if it's an LS or an LQ... your looking at about $8k for something that makes 500'ish HP. The LS just does it with less weight.
Old 02-02-2009, 10:53 AM
Stang's Bane Stang's Bane is offline
If you start buying used though, the iron ones are significantly cheaper...
Old 02-03-2009, 04:22 PM
00fxd's Avatar
00fxd 00fxd is offline
I have a line on a low mi LQ9 right now for a good price. I'm holding out for an all aluminum, low mi L76 . Maybe I'm crazy but I would also like to make the DOD and Variable valve timing work with a manual trans [Muncie]. Gotta talk to an Ecm guy. Any suggestions?
