Old 02-05-2009, 10:23 PM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
Default intercooler suggestions
Im at that critical point of trying to find an intercooler that will fit and perform to achieve my horsepower goal. Trying to decide in front of the radiator or in front of the core support. I only have about 3.5 inches of room from my fans to the ls1 pump. It will definately be air to air and hopefully be able to achieve approx 1000hp. Any suggestions or anyone done this on this car that can point me in the right direction?
1965 chevelle ls1 twin turbo/th400/currie 9 inch
Old 02-06-2009, 12:27 AM
Blown353 Blown353 is offline
Figure out your available dimensions and then give an expert a call. I highly recommend Bell Intercoolers; I worked with Gerhard when I designed my intercooler. Very sharp and helpful guy to talk to... and they build nice stuff too.
Here's what you're looking at to support 1000hp or so with minimal pressure drop:
https://lateral-g.net/forums/showthread.php4?t=8304
https://lateral-g.net/forums/showthread.php4?t=9204
The intercooler will be plenty adequate for the new TT LS2 I'm currently building. It's about 4" taller in core height than Gerhard's recommended "minimum height" but I had the room to go up a bit and he suggested if I had the room to stretch it a bit to add additional efficiency. The core is 27" x 12" x 3".
If you can't fit an adequately sized intercooler you can actually hurt power because it becomes a restriction. You want the largest cross sectional area possible in the charge air direction for minimum pressure drop.
1969 Chevelle
Old 02-06-2009, 06:59 AM
Another vote for Gerhard at Bell Intercoolers. We have 2 - 12x12x3.5's for a twin T61 turbo'd LS2. The intercoolers are rated at 550hp each. The craftsmanship, turnaround and service is excellent!
Jeff Allen
J2 Speed and Custom
Old 02-06-2009, 09:49 AM
I'm going to 3rd that... I called a lot of people and went with Gerhard as well at Bell intercoolers.
Old 03-27-2009, 05:51 AM
buds87gn's Avatar
buds87gn buds87gn is offline
Precision Turbo might be able to help you out...
Erick
"Land of pleasant living" White Marsh MD
9sec. 87 Buick Grand National money pit
68 Camaro rustoration project
Old 03-28-2009, 08:41 AM
64duece 64duece is offline
We use Bell cores for our custom builds. We offer our feedback aswell as take Gerhard's advice to come up with the best intercooler for the application. He's a great guy to share and receive knowledge on this particular subject.
That being stated, we've done one 69 Chevelle twin turbo project that started as an air to air system. We found we couldn't support our hp with the available area and we ran into cooling issues with a smaller Procharger core blocking radiator air flow.
Dennis
Moore Racecraft
