Old 02-12-2009, 12:41 PM
BANKO's Avatar
BANKO BANKO is offline
Default Legal Ride Height Minimum in CA?
Hey guys, I did some quick web searches to see if I could find any restrictions on the minimum ride height for vehicles in California. I would like to build a '65 Chevelle someday where frame sits about 4" off the ground. Any info would be great.
Thanks, Josh
Old 02-12-2009, 01:16 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Modification of Vehicles
24008. It is unlawful to operate any passenger vehicle, or commercial vehicle under 6,000 pounds, which has been modified from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lowermost portion of any rim of any wheel in contact with the roadway.
Amended Ch. 462, Stats. 1984. Effective January 1, 1985.
Frame and Floor Height
24008.5. (a) No person shall operate any motor vehicle with a frame height or body floor height greater than specified in subdivisions (b) and (c).
(b) The maximum frame height is as follows:
[This table lists the maximum frame height for various types of vehicles.] * Vehicle Type Frame Height
(1) Passenger vehicles, except housecars 23 inches
(2) All other motor vehicles, including housecars, as follows:
Up to 4,500 pounds GVWR 27 inches
4,501 to 7,500 pounds GVWR 30 inches
7,501 to 10,000 pounds GVWR 31 inches
(c) The lowest portion of the body floor shall not be more than five inches above the top of the frame.
(d) The following definitions govern the construction of this section:
(1) "Frame" means the main longitudinal structural members of the chassis of the vehicle or, for vehicles with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle.
(2) "Frame height" means the vertical distance between the ground and the lowest point on the frame, measured when the vehicle is unladen on a level surface at the lowest point on the frame midway between the front axle and the second axle on the vehicle.
(3) "GVWR" means the manufacturer's gross vehicle weight rating, as defined in Section 390, whether or not the vehicle is modified by use of parts not originally installed by the manufacturer.
* The bracketed information has been added editorially to meet accessibility requirements and is not part of statute.
Amended Ch. 718, Stats. 1987. Effective January 1, 1988.
Old 02-12-2009, 01:20 PM
ironworks's Avatar
As long as everything is higher then the side profile of tire you are fine.
Old 02-12-2009, 03:18 PM
JamesJ JamesJ is offline
I am not trying to get into a long discussion of what is legal and what is illegal but am I reading this wrong, to me it looks like that all the lifted truck are not legal? Does the DPS just not car about them?
James J.
Old 02-12-2009, 03:49 PM
caper150's Avatar
caper150 caper150 is offline
James, I see your in TX and those laws that were posted were for CA. They vary from state to state.
__________________________________
Darryl
My projects
1965 Ford Galaxie Big Block and 4Doors Project HULK
1966 Ford Galaxie 2 Door Sedan Project unnamed 4.6L Crown Vic runnig gear
Old 02-12-2009, 04:25 PM
MtotheIKEo MtotheIKEo is offline
frame has to be higher than the bottom of the wheel. i.e. if you get a flat you should still be able to roll the vehicle.
Old 02-13-2009, 10:17 AM
I have seen many lifted trucks when I am in CA...
James J.
Old 02-13-2009, 04:44 PM
chicane's Avatar
chicane chicane is offline
Trucks have 'head light', 'bumper height' and 'mud flap' laws... but are rarely enforced anymore. There were a few years where they were... but thay has gone wayside. It is more of a 'wrong place at the wrong time' kind of violation anymore...
Old 02-13-2009, 05:06 PM
camaro2nv's Avatar
Everything posted just depends on the cop. If hes havin a bad day then look out!
Old 02-13-2009, 05:38 PM
awr68's Avatar
awr68 awr68 is offline
This is the law here in Oregon...and from a safety standpoint I follow it.
Tony
'68 Camaro
