Old 02-13-2009, 08:22 AM
Rusty G Rusty G is offline
Default Handling Alignment Specs 4 Gbody
Sorry for the trickery but 5 days 29 views and no-one has any input on an alignment for a G Body?
Due to some recent suspension work, thanks to a nice deep Pa pothole , I am going to need to get the front end aligned.
The car is a 83 Malibu wagon.
FRONT: Poly bushings threwout, 36mm front bar, Edelbrock IAS Shocks, Solid tie rod adjusters with new ends(4),Monte SS front springs
REAR: Boxed lowers with Poly, Anti-hop bars with non boxed upper and Camaro rubber bushings, IAS Shocks, 1" and 7/8" rear bars (yes 2)
I have a set of TRZ Upper arms that I would like to use also.They have built in 7 degrees positive caster.
Also have stock upper arms,stock shaft and MOOG offset shaft availible to use.
The car is my driver so I am looking for specs that are somewhat of a compromise between all out handling and tire wear.
28
