Old 02-13-2009, 10:08 AM
Tempstop Tempstop is offline
Default LS7 with an Automatic--options with cruise control
I have a 69 Camaro in the planning stages. Already have a ls7 out of a z06 and plan to mate it to an automatic. Talked to John at Speartech about a harness. He told me the only transmission he has been able to have cruise control behind a ls7 was a 4l70e.
I was wandering if anyone had any other better options. I really like the compushift option with paddleshift, but I think I like cruise control better. Was wandering if I can have it all?
Knew a guy with a bunch of new GM 4l70e units with converters for $1200. So I bought one. Now I would like to upgrade the transmission with the necessary parts to make it a little more likely to live behind the ls7. Wanted some recommendations of which parts to replace. Also interested in some recommendation on a converter. I'm not a racer, so not looking for this aspect.
Thanks Tim
Old 02-13-2009, 06:29 PM
customcam's Avatar
customcam customcam is offline
Id do the Paddle Shifting instead of cruise control thats just me personally, more fun have you seen them in action? changed my whole thoughts on those transmissions, behind a Ls7 look at high tens
Old 02-14-2009, 11:34 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
What about the 4l80e. And I know that GM has released a six speed auto but i do not know if anybody has put it in an early model. Does anybody else know? Also why not manual you can still have cruise control?
Old 02-15-2009, 08:07 AM
Steve Chryssos's Avatar
We've worked with at least 6 people on 6L80 swaps. A few are already running driving cars. With that said, you should approach the swap as unchartered territory--mostly from a calibration standpoint. But HPTuners has made great progress on calibration tweaking. Te big question is: How much of that can be applied to pro-touring type swaps as opposed to OE 6L's such as C6 vettes, G8's, etc. The answer is coming.
As for this particular application--LS7 with GM ECU and 4L, you will need the following to have it all (cruise control and paddle shift):
-GM ECU with trans type parameter set to M6 (not A4)
-M6 harness
-Compushift with standalone transmission harness
-Shrifter® Paddle Shifter
-Aftermarket standalone cruise control such as Rostra aftermarket unit.
And I strongly recommend one of our MuscleDrive converters to take advantage of the LS7.
________________
Steve Chryssos
Ridetech.com
Old 02-15-2009, 11:26 AM
98ssnova's Avatar
-M6 harness
-ShrifterŽ Paddle Shifter
I stand corrected and great awnser.
