Old 02-14-2009, 03:19 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default crack in transmission case
my tranny was leaking pretty bad so i pulled it out thinking it was a seal and turns out i have a hair line fracture in it can you weld this shut or jb weld it shut for a temp fix
jcal87's Avatar
also it is a muncie 4 speed m21
Old 02-14-2009, 03:44 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
As a temp repair I guess so but your case has damage and will only progress and get worse I wouldn't want a gear fraging out through the at 70 mph . I could be wrong but you need to address this ASAP. If you are driving the car daily.
Old 02-14-2009, 05:22 PM
jcal87's Avatar
is there any kind of mig weld i can do on an aluminum case?
Old 02-14-2009, 05:41 PM
98ssnova's Avatar
I would imagine that you could but with all of the rotating that goes on there is some pressure that builds up. Brfore you have it welded I would get it checked for cracks. Honesly buy the time you get done with this you probaly could have just bought a very nice used one. Just my .02
Old 02-14-2009, 05:45 PM
War's Avatar
War War is offline
That's a nice way to say quit while your ahead
Jason
Old 02-14-2009, 05:48 PM
jcal87's Avatar
well it is cracked and i own a welder but can you mig aluminum or can i jb weld it
Old 02-14-2009, 05:56 PM
98ssnova's Avatar
OK bro well weld it up and run it I am not a pro welder but i though you just put a brand new motor in your car and I'm sure it has some power. When that get transfered through the tranny it will over time exposed the weakness in the metal. But please weld it and I hope it lasts forever but if it doesn't sorry for your luck. Also have you figured the cost of removing all the gears and plates in the tranny I'm sure you wouldn't weld it with all of that still in the case. BUt good luck to you sir.
Old 02-14-2009, 06:01 PM
jcal87's Avatar
well i figured when welding aluminum low voltage is a must and didn't think it would effect the gears inside the casing but if you think different please tell me that's why i posted on here to learn but the engine is not new by any means and this car is not a daily driver i just need it to get by until one day i upgrade the engine and tranny
Old 02-14-2009, 06:03 PM
Sounds like you found your noise.
