Old 02-14-2009, 05:20 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default DSE Sub Frame Connector Install
I recently installed a new full floor in my 68 Camaro and I have a question about the DSE sub frame connectors. Since you have to cut the seat pan brackets for the installation of the SFC's, should I just wait until I install the connectors and then install the seat pan brackets?
I was thinking I should probably install the brackets first to help stiffen the subframe mount area for when I bolt the sub frame up and align it to the rear frame rails.
Any suggestions?
Chris
Old 02-14-2009, 05:43 PM
War's Avatar
War War is offline
Install the seat pan after. That way you can back prime and won't have that piece to weld back in.
Jason
Old 02-14-2009, 06:10 PM
Steve1968LS2's Avatar
I would do it afterwards as well. Stiffening the floor shouldn't be a problem since the car needs to be on it's wheels (or simulated). Unless of course there's no drivetrain in the car (ie, it's light).
Here's a story I did a while back on the install:
http://www.popularhotrodding.com/tec...ors/index.html
Old 02-14-2009, 06:46 PM
ItDoRun's Avatar
I was planning on getting the car off the body cart and putting it on jackstands, then installing the subframe and aligning the front sheet metal. Once I get the subframe aligned to the rear frame rails, I planned on installing the sfc's and then welding the brackets.
Chris
