Old 02-18-2009, 08:08 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Radiator Hose Ron Davis LS1
Does anybody have a part number for LSX conversion upper and lower hose? I'm using a Ron Davis LS1 Radiator. I figured it's been done so much there might be some part numbers out there.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 02-18-2009, 09:17 PM
camcojb camcojb is offline
I made hard lines this time, but I've ALWAYS been able to get a molded hose to fit by using a coat hanger or welding rod bent to the angles I needed and then heading down to the local auto parts store and going through their hose selection. You may only use part of the hose, or have to trim one end, but in all the swaps I've done in years past I always find one with the proper bends by making a template from welding rod or similar.
Hopefully someone can help you with exact numbers, but if not give this a try.
Old 02-19-2009, 07:35 AM
Fluid Power's Avatar
That is exactly what I did. There is a local NAPA and I have gotten to know the guys really well. They let me look thru the books and go thru the hoses to find what I needed. Great guys.
Darren
Old 02-19-2009, 07:51 AM
I have understood at F body hoses will do
63 Z06
Old 02-19-2009, 10:07 AM
War's Avatar
War War is offline
I believe these are Napa PN#'s
Upper 8301
Lower 9038
I haven't tried them but I read somewhere these were correct.
Jason
