Old 02-25-2009, 01:26 PM
James OLC's Avatar
Default Official OLC Garage (?) Sale
I guess this is the Official OLC Garage Sale…
Somehow I wound up with a bunch of parts and pieces left over after the Camaro was together and I need space and cash so I need to get rid of some of this stuff. This is a partial list for now, I’ll add to it and include pictures when I get home tonight but time is of the essence on this so I wanted to at least get the thread started:
Harwood fiberglass Cowl Induction hoods (2 available) $400 obo (each)
New, never used, in “as delivered” condition. They are stock height, bolt on (used hinges and front latch) and are designed to fit 1967 to 1969 Camaros. Harwood part number B-10101.
1968 Camaro RS Reproduction headlight assemblies $200 obo for the pair
Never used, one door is slightly scuffed but nothing major, some hardware might have been swapped with OEM but all present. Includes a grab bag of misc (new repro) parts.
1967 Camaro Dash (2 available) $125 obo (each)
Not the gauge part - the actual metal dash itself. Both are original and in really good condition.
Tilton 40-524 Oil Pump (transmission, differential, etc.) New in the Box $135 obo
Brand new - never seen power or fluid.
Everything is currently located in Calgary, AB Canada but will be available for pickup in or around Costa Mesa, CA around March 12th. If anyone wants any of this I will need to know by March 6th so that it winds up in the trailer.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-25-2009, 01:27 PM
James OLC's Avatar
Global West Upper & Lower Control Arms with Del-A-Lum bushings(First Gen Camaro)
$350 obo for the uppers, $450 obo for the lowers
Originally used for ATS's SEMA display frame, these were slightly damaged in shipping and one of the uppers needs a new ball joint. Both are scratched from rubbing against one another in the box while Fed Ex sent them on an extended trip to nowhere. THE LOWERS HAVE BEEN CONVERTED FOR COIL OVERS using the ATS Chicane-LM kit. Did I mention that they fit first generation Camaro's?
Hyperco Front Springs - 475#, 12" extended (free length), 3.5" OD, 2.5" ID $100 obo for the pair
These are new and were used for mock up only.
I have to check part numbers and condition before I add them, but stuff coming tomorow includes a Canton Power Steering remote reservoir, a Setrab Oil Cooler, and probably some more bits and pieces (LS7 factory fuel “rails” and coil pack mounts).
James
1969 Camaro - Dusty
James OLC's Avatar
I-Squared 1+1 Electrical System - New in the box $600 obo
Used for mock up only, never powered, complete with instructions.
LS7 Drive by Wire Throttle Body - New, Never Used - $175 obo
Also fits LS2 and LS3. Does not include any sensors
LS7 Katech Spark Plug Wire Set (for relocated coils) $50 obo
K&N Filter PN RF-1040, new in the box $40 obo
4" flange, 9" long, 5.75" wide, 7.5" high
Dr. Gas - Spin Tech Mufflers. Oval Pro ShootOut PN 4991-35 New in the Box $200 obo (pair)
These are brand new (one box has never been opened) and are 3.5" oval center in and center out design
I also have…
1998 Camaro LS1 $1,100 obo
I bought it off the site with 84K (it was the deal from hell – my bad) - it’s pretty much complete except for the wiring harness (never had one). It needs an intake (was cracked on removal, I’m assuming) and new sensors at the very least. I was told that it was mechanically sound but can’t vouch for that – I bought it for mock up purposes and that was the extent of it.
James
1969 Camaro - Dusty
Old 02-25-2009, 03:40 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default I2
PM sent on Isquared...
Old 02-25-2009, 10:24 PM
James OLC's Avatar
All PMs responded to.
More coming tomorrow including a complete Tire Mount Mate tool.
James
1969 Camaro - Dusty
Old 02-25-2009, 10:32 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
James...why not just build another car. I seem to recall the wife wanting one.
Curtis
Old 02-26-2009, 12:03 AM
PM sent on K&N
63 Z06
Old 02-26-2009, 01:25 AM
skatinjay27's Avatar
she already has one! dont you remember where james got all his oem front metal from!lol
AJ
Old 02-26-2009, 06:50 AM
Moose Moose is offline
how long are those plug wires? I think I may have misunderstood what they are..
Old 02-26-2009, 08:19 AM
James OLC's Avatar
I can measure them when I get back to the shop. These should fit anything with an LS and are designed to be used with Katech's coil relocation kit:
They are obviously a bit longer than stock.
James
1969 Camaro - Dusty
