Old 09-26-2005, 12:41 PM
MaxHarvard's Avatar
Default How much power could this combo hold up to?
Ok folks, i've now completely upgraded my rear end... nearly 100%.
its a 8.2" GM 10 bolt with an Eaton Posi. 3.73 Richmond Gears and a brand new set of Moser axles.
Any idea what that combo could hold on a consistant basis? I've i go bigger with the motor, what might be the limit for HP? I'm only at 450 at the crank now.
Old 10-03-2005, 04:01 PM
mazspeed's Avatar
mazspeed mazspeed is offline
I have the exact combo you have except for the strange axles. I asked this same question as I have a modded ZZ430 motor putting out around the same power, and I have been told it should hold up fine, but to take it easy on the drag race starts. If you don't abuse it like anything else it should (or so I'm told) hold up fine. I'm going to have a custom 12 bolt when I pull the motor out though.
Old 10-03-2005, 06:28 PM
lil427z's Avatar
lil427z lil427z is offline
maxharvard. i thank the power it will handle 1.2 to 42.5 hp after that you have broke it lol.
rick kirkindall keep up the good work
