Old 09-26-2005, 04:08 PM
MaxHarvard's Avatar
Default Wheel spacers?
Ok, i know they arent that good for your car, but i've run into a problem where i've boughten a set of rims that are "suppose" to work, with all the same specs from camaros.net that others say that have used, but i'm running into rubbing issues, especially when i take corners. I figured using a 7/16th spacer would eliminate the problem... thoughts?
It isnt rubbing too much on the inner fender well, very minor, havent even rubbed off the lettering on the tire!!
Btw, its the rear tires we are talking about.
Old 09-27-2005, 07:00 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What are you wheel/tire specs?
What bushings are you using?
Doesn't sound like it rubbing very bad, so if you need a spacer, use the smallest one that'll work. Start with a 1/4", and go from there. Make sure your studs are long enough too.
Old 09-27-2005, 07:36 AM
MaxHarvard's Avatar
i have TTII's on the rear, 17x9.5 with 5.5 BS
