Old 03-12-2009, 09:45 PM
pleiku10 pleiku10 is offline
Default Panel replacement
I have noticed on a lot of rebuild pics that some cut off every panel that needs to be replaced all at once. Doesn't this unspring everything and make it more difficult when trying to line all the new panels up? Would it not be wiser to start one side then the other? Your thoughts Wise Masters please!-Mike
Old 03-13-2009, 12:00 AM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
you only want to remove all the panels if you have jigs to hold the existing structure in place otherwise do one panel at a time
Luke Mau
L & H Kustoms
Old 03-13-2009, 06:28 AM
I am not a big cut it all apart at once guy. I like to make seperate jobs of them, unless everything is SO BAD you have to just blow it all apart, which we have had to do.
Frank Serafine
