Old 03-20-2009, 09:43 PM
68FBODY 68FBODY is offline
Default Lifter Help......Best lifters
Ok well I got off the phone today with kauffman/KRE because i am going to use a set of their aluminum d port. my cam I just bought is a lunati 241/249 110lsa hydraulic flat tappet. Jeff told me I would easily be able to hit over the 500/500 mark with a 468ci and their d ports with that cam on 87 octane even! Now my question who has the best hydraulic lifters, I looked at the Lunati performance lifters for higher rpm and the isky anti pump up lifters. Anybody know of anything else?
Sorry its so long
Thank you
1968 Firebird Pro-Touring project
1967 Mustang Fastback Pro-Touring project
Old 03-20-2009, 11:09 PM
You have no worries about high RPM operation with a 241 / 248 cam in a 468CI. That thing will be done at 5700 or so. I suspect that cam is right at .500 lift, And just about any lifter is good to 5700 and .500 lift.
Frank Serafine
Old 04-12-2009, 05:37 PM
Huneycutt's Avatar
Huneycutt Huneycutt is offline
This may be something you already know, but if you are doing the work yourself, be careful when breaking in your flat tappet cam. It is hard to get motor oils currently that have enough zinc to protect flat tappet lifters. The stuff harms oxygen sensors and the oil companies have taken it out since most OEM engines now have roller tappets.
If you are intersted, I put together a video on breaking in your flat tappet camshaft on my website. You can see it at StreetMuscleAction.
StreetMuscleAction.com
Old 09-30-2009, 02:34 PM
Huneycutt's Avatar
Sorry, the website blew up last week, and in the process of getting things up and running again, my web guru did something that changed all the permalinks. The correct link to get you to that video--if anyone is interested--is:
http://streetmuscleaction.com/engines/flat-tappet/
thanks
Old 10-01-2009, 10:00 PM
The T-man The T-man is offline
the Lunati hi-revs are killer
Old 10-02-2009, 09:03 AM
I agree with Frank... you shouldn't have any lifter issues to start with.
Make sure you measure your pushrod length... and break the cam in correctly - both of those things are more important than what NAME brand of lifter you'll choose.
Old 10-02-2009, 09:13 AM
Honeycut -
Great video -- thanks for reposting it. I've seen it before - and anyone building an engine should see it. Especially if they're newbies. But it's always a good reminder too!
I learned something about the spinning pushrods - making a mark on them is a killer 'tip'.
