Old 03-23-2009, 06:39 AM
DOOM's Avatar
DOOM DOOM is offline
Default 9 inch axe ?
Mike (MCC) finished my 9 inch '' torino'' bearing .My question is ,on the Kore3 web site they tell you you have to machine the axle face? Im using the Zo6 calipers and rotors will I need to do this for this application?? And who's axle's would you use? I have STRANGE in my back yard..
Mario
USCOLLISION
Old 03-23-2009, 06:42 PM
Apogee Apogee is offline
You'll need to make sure that the outside diameter of the axle shaft is ~5.94" with a decent edge break (1/8" x 45) on the face so that the C5/C6 rear rotors seat fully with the axle, otherwise your could have issues with your wheels not staying torqued down properly, not to mention some caliper/rotor misalignment issues. If you've already got axles and rotors, then it should just be a matter of verifying the fitment between them. If I'm unsure a rotor is fully seating against the face of the axle, I'll usually just put a small dab of grease on the face and then install the rotor. If it's squished flat, you're done. If not, then you've got some more work to do.
Tobin
KORE3
www.kore3.com
