Old 03-27-2009, 09:01 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default LS2 Accessory Drive in a 1st Gen Camaro
Will the LS2 accessory drive system from a 2006 GTO work in a 1st gen Camaro? I know the frame will need to be notched for the a/c compressor, but what else?
Chris
Old 04-05-2009, 01:01 AM
You could try http://www.kwikperf.com/products.html there brackets will move the ac and alt up top so no cutting needed.
