Old 03-30-2009, 02:35 PM
latzoo latzoo is offline
Default 67 Roof drip rails
Now that I have started reseaarching my roof replacement I saw some sweet cars with the drip rail removed. Is this as simple as cutting the drip rail off and filling the hole with weld. Or would this require some professinal help.
I feel that I competent enough to start the roof next week and would like to also tackle this at the same time. My drip rails don't look too hot so this might be a cost effective way of customizing/ repairing a section of my car.
Thanks for the help.
Old 03-31-2009, 01:46 AM
D Rock D Rock is offline
I had it done on my camaro, body man just cut them off and welded the seam shut. Just go slow so you don't warp anything.
Old 03-31-2009, 06:33 AM
That's what I was hoping to hear.
Old 03-31-2009, 11:41 AM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
I would find a car that has this done and see if it looks good before hand. Some cars would look like crap with this done.
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 04-05-2009, 09:23 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I have talked to a few guys about this. If you are going to do it, only remove about 3"-4" of drip rail then weld up, cut more, weld up. Take your time. If you cut the whole drip rail at once you will have issues with the roof skin wanting to move around, twist etc...
Guy
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
