Old 03-31-2009, 03:58 PM
madcarson madcarson is offline
Default Fuse panel location ?
looking for ideas where to mount fuse panel in 69 Camaro,I have the Hwy 22 kit so it's too big for orig.location.I was thinking on the trans tunnel just behind shifter but then I have to build a custom console,any other options
Old 03-31-2009, 11:04 PM
I have Highway 22 too. I am planning to put it in the glove box. DSE install it up in the trunk. It had hinges to turn it visible.
63 Z06
Old 04-01-2009, 05:53 AM
Payton King's Avatar
Default I have the same kit
Placed mine behind the glovebox door. I have Vintage Air, so I do not have much room. If I did it again, I think I would put it in the trunk...might do that next winter.
Old 04-01-2009, 06:48 PM
I have a real nifty little area for that but photobucket is down...........again. Will post a pick later
Frank Serafine
Old 04-01-2009, 07:56 PM
nvr2fst nvr2fst is offline
I had mine originally under the rear seat. Easy to see labeling, easy access and a non cramped area once seat was popped out.
Old 04-01-2009, 11:59 PM
I want to see it too
63 Z06
Old 04-02-2009, 07:44 AM
VP23271's Avatar
VP23271 VP23271 is offline
Frank, I was considering putting the fuse panel in the trunk close to the battery too. Keep us posted on the pic's/info.
If I see you in Del Mar, I will chat you up
Rick
"Better to Be Lucky than Good "
Old 10-13-2010, 07:54 AM
brans72 brans72 is offline
Anymore ideas or pictures guys? bringing a old thread to light. Brandon
